MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Thu Jan 10, 2008 9:07 pm
There's no difference. The stickers both mean basically the same thing, though. The sticker on the I is saying that 87 is fine but higher octane will allow for more power. The case is the same with the Max. Both have the same motor, and both can compensate for knock by retarding timing, which reduces power. You are both okay running regular unleaded.
You don't need to know fuel tank capacity to calculate MPG. All you need to do is make sure you fill up completely but don't top. Then the next time you fill up, do the same, and divide the distance traveled by the amount it took to fill the tank again. There's your MPG.But, yes, 70 liters or 18.5 gallons is correct. There's no reserve tank.
