rn240sx wrote:Well I just got an email back from a buddy of mine who has the opposite theory...1: well, octane burns slower2: so you can run it leaner without the gas detonating3: you can go leaner because with 100 you can run like 14-1 A/F ratio's4: where as normally you should be at like 12-15: so that means for the same amount of fuel you can pump in more air
He's right.. to a point. There is no way to tell, without dyno results, to say that "100 octane will let me run 10psi." And I really think that the ammount of boost you could actually add would be virtually nothing. As I said before, when people have 72# injectors, they have enough fuel (using the BSFC formula) for 450hp. For 450hp, a KA-T would need 25psi or so. The thing is.. with a smaller turbo, you run out of efficiency up there, so you create more heat per extra psi you squeeze out. Then the FMIC can only cool so much air at a certain efficiency. This is where race gas comes in. The injectors can handle the boost at 25psi, and the hp, but the air is super compressed in the cylinder, and the heat from the compression, and running out of efficiency on the turbo will make the gasoline detonate before you want it to. Race gas prevents the detonation. It's not that it allowed for more power directly (it is not acting like more gas). It simply prevented detonation, which in turn allows more boost. The injectors comfortably handle that power... it's the gas that didn't.Race gas you can turn the timing up some (our ECU retards the timing when using lower octane, or making boost enough to cause a knock.) Leaving all else alone, advancing the timing from race gas will allow more power. Also, you can lean it out and create more power.370cc injectors (35#) are good to 260-280hp, depending on tuning. If you are making 260hp at 8psi, you'd make 280-290hp at 10psi. Without great tuning, you won't be able to handle this power for prolonged periods.. because you are causing detonation. Not from heat or compression, but due to lack of fuel. A pound of boost is really alot of air to add fuel to, and alot of power (10hp, or more in some setups). So while race gas may handle 5-10hp (as I said, usually from timing advancements), it won't handle the 20hp+ from more boost that you'd need while lacking the fuel for it. So yea, it'll help, but there isn't a way to precisely determine how much more boost or power you can run simply by adding 100 octane, without a dyno. Cliffs Notes: Race gas helps. You can't tell how much without a trip to the dyno. I wouldn't try upping 2psi of boost on race gas without an accurate A/F reading (GReddy a/f gauge, wideband, dyno), because you are at the limit of power 370cc injectors can handle. -Jeff
