Octane Booster for SR20DET
Phax
Car: Control dynamics
I read in the factory service manual that Nissan suggests 97 octane gasoline for the S14 SR20DET. I live in Southern California, where gas sucks and they've already added things like MTBE to get us up to a whoppin, 91 octane (for about $2.30+ a gallon, last I checked). Are there any off the shelf octane boosters that I can use, to significantly up the octane level?
If there aren't, I might have to seriously keep the S13 as the night time / weekend warrior vehicle.
S13240
Cattalbus
Car: Cars
Run and run fast do not mix that crap in your fuel. unless you like to hurt your car. just find a car that runs on pump gas or buy race gas.
GraySilvia
Car: auto-x, drag racing, beer
I think the 97 octane that is referred to in the manual is using another method for calculating octane, the one that they use overseas, not the (R+M)/2 method like we use....don't they use just R or something?!? I dunno much about octane ratings.
I H8 UR DSM
yea, japanese use a diff method for calculating their octane...97 there doesnt equal 97 here...sorry i dont know the conversion
joe3180
Car: 89 240sx, S13 sr20det, silvia conversion
ya japan just uses the r rate system go here... http://www.btinternet.com/~mad....html
Red Lightning
Maybe this will help. Alcohol raises the octane by 5% or so and it cools the intake air temp.
lessthanjakejohn
Fuel Formulas
Red Lightning
Has anyone on this board actually tried the Toluene mix? Does it work? :confused: As for alcohol, it would be better just use a alcohol injection kit (and as Madscientist mentioned in another thread, use Mystery oil), so it will not eat away the gas tank.
brent
Car: cars, racing
I tried the toulene mix in my MR2, and didn't notice a difference
DAEDALUS
Car: 1990 Infiniti Q45
Sorry I'm late, just found this thread. I used 3 gallons toulene mixed into my 20 gallon tank. Placebo effect maybe, but I thought I felt a difference. Shoulda been 95 octane mixed together, so there should be a difference I think. The cheapest I found toulene for is about $7/gallon, not as cheap as what's been stated online, but cheaper than the octane booster crap sold at Pep Boys.
RobDET
Car: Cars
Higher octain won't help unless you are loosing timing becuase of detonation. Then increasing the octain will bump your timing back up and give you more power... But if you can run 87 and get no nock then 91 won't help unless you turn up the boost.
on toluene A firned with a GN was getting 6 degrees of retard in drive on 93 octain. He added the recomended amount of toluene and the timing went back to full advance
