goofynick6 »
https://forums.nicoclub.com/goofynick6-u13220.html
Tue Mar 22, 2005 5:19 am
Higher octane is used to prevent detonation, detonation that comes with elevated intake temperatures and/or increased ignition timing.
The increase in octane basically means the fuel is less prone to igniting early due to hot surfaces in the combustion chamber, rather than by the properly timed spark from the sparkplug.
I run 18psi on a big turbo and around 22 degrees timing when I'm running the car hard. Different turbos are more efficient at different boost levels, some make the best boost at 12psi and the air isn't overly hot, and the intercooler takes the heat out; however that same turbo at 18psi might be out of its efficiency range and making that boost level with extremely elevated intake temperatures, causing the detonation and knock.
My turbo is happy at 18psi, but if I wanted to run maybe 20psi and maybe a couple degrees more timing I would run race gas, or if I was at the track really beating on the car and heating it up I would run some just as a safeguard, because an engine can only take so much heat and abuse, some more than others obviously (2jz's can take lots).
So, don't waste money on anything over 93 octane until you're running higher boost and timing, and don't run less than 93 octane with a high performance/boosted engine.
HTH,Nick
Modified by goofynick6 at 11:56 AM 3/22/2005
