octane boost...anyone use this? results?
MarkEmark
Car: fully-built '95 240sx KA-T
Wondering if anyone uses that 107+ octane boost and if they can testify to any noticeable power increase...I use 93 octane regardless, if I added the boost, would it make it any better? Is it detrimental at all to the engine's well being? Thanks
MasterMan
Car: nothing running at the moment city buses "uck here
stuff u buy at the auto store? yeah i bought some.. dont think it did much of anything.. my bro has a honda and said he could tell a diffrence but i dunno could be that hez just a moron :)
PabloHoney
Octane booster shouldn't be used unless you are running very high compression NA or high boost turbocharged engines. From looking at your sig MarkE, putting octane booster in your car will only make you lose power. Octane booster simply makes the fuel less susceptible to detonation. In other words, it's hard to ignite. More than likely if you were to run 107 octane (which isn't what that 107+ stuff will do), a lot of the fuel wouldn't be ignited.
MasterMan, in your brothers honda, he is a moron. Most honda's (not the B or H-series engines) will run much better with piss water 87 octane. I have seen a few dyno charts where going from 87 - 93 octane created a 2-4 hp loss.
SpeedRacer1
Car: 1990 240SX, G35
You can use octane boosters if your using a big shot of NOS and not retarding timing.
240SXer
Car: 1995 240sx SE (2jz powered)
Maybe if you wanted to advance your timing more the boost would help it not detonate, other than that I'd think you'd lose power if anything.
David.
matt240det
octane boosters are garbage,, it does nothing whne it says it reaises your octane "7 points" then mean your 93 will be 93.7 waste of monet if you want high octane get something like c 116 or real race gas
