Jesse SR20 »
https://forums.nicoclub.com/jesse-sr20-u17540.html
Sun Aug 07, 2005 2:54 pm
Is it white smoke ? Or is it greyish blue ?
If it's pure white, it's actually steam. It's coolant/water being burned in the cylinders (most likely the head gasket).
If it's blueish in cooler, it's oil being burned. Oil can leak from numorous places. Seals in the turbo, piston rings, valve seals, just to name the obvious.
You can also determine if it's water or oil by the smell. In either case I wouldn't let this go on much further.
