C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sun Jul 25, 2004 3:16 pm
I'd be skeptikal of anything that thickens the oil. Even if it mixes with the oil well, it would change the overall viscosity. While this is not going to kill your motor in that of itself, yould be doing something similar to just using a heavier weight oil.
As far as the proiblem itself, I'd suspect the valve stem seals. If it smokes mostly after idling or decelerating the motor for a long period of time(slowly stopping while in gear), this is most likely the cause since the intake manifold will see high vacuum and if the seals are bad, it will suck some oil past the seals. Then as you accelerate a large amount of what oil was drawn into the intake mani gets pulled into the combustion chamber burned and spewed out the exhaust.
