tinfins »
https://forums.nicoclub.com/tinfins-u187996.html
Tue Nov 27, 2012 10:29 pm
I own a 1996 n/a Z32 with about 70k original miles, my clutch recently started slipping and gave out so I put in a brand new and much better clutch and flywheel.
Ever since then 1 out of every 10 to 15 times I start the car it will grind really loud and not start. However if I put the car neutral and physically push/roll the car a few inches after this happens it starts up totally fine like normal with no more grinding.
I'm thinking the starter may be grinding with the flywheel. It is the cars original starter. Since it doesn't happen too often and since I can always still get the car started...should I worry about this immediately, or will it be OK to wait a while till I have more time to fix and look into this in January, has anyone else experienced this same situation? I just don't want to damage anything else.
Thanks,
Kyle
