znelson »
https://forums.nicoclub.com/znelson-u36902.html
Sun Jan 07, 2007 3:03 pm
Header Install + Heat Wrapping for the KA24DE S13. Guide by Nlzn
Time to Install: 2Hours, maximum. Helps with a friend or a second set of hands.
Parts Needed: Headers (I used KA OBX Stainless for this, welds looked good, and they aren't very expensive.)Heat Wrap (rougly 20$ for 50ft, and you'll need every bit of it.)1 5" Hose Clamp (~99cents @ Wal-Mart)Some type of gloves, I used Nitrile (Auto-Zone, $4 a box). You don't want to handle the fiberglass wrap with bare hands.Electrical TapeScissorsWrench to get old headers off and put new ones on.1 Nickel (yes, 5cents)
Step1: Now that you have all the parts you need, the quickest part of this guide is removing your old headers. This is pretty
self-explanatory, remove the eight screws from the head studs, unbolt the downpip from the catalytic converter and youre done here. Oh ya,
don't forget to remove the o2 sensor. Some people find it easier to seperate the stock headers, I took mine out in one peice. Mechanic's
choice here.
Step2: Prep the headers for install. Since I chose the time go ahead and get rid of EGR and emissions etc.. before the install it might be
wise to weld off the EGR tube port. I know my weld isn't the prettiest but it works. Second I used a nickel and wrenched down the hollow pipe
fitting (you can find this on your old headers) on it as hard as I can turn. Made an air tight seal and worked great.
Step3: Wrapping the headers. We approached the headers asking how to make it look good and with the use minimal wires/clamps. We finally came
up with a good solution that only took us one clamp for the whole project. We started our wrap with runner #3 as shown in the picture. It
really helps when you cut the wrap to take the electrical tape and tape over the end of it so you don't have to worry about excess threads.
Make sure on the first wraps, this is very important, that you double over once extremely tight. All the wraps need be as tight as you can
get them at the start or you'll end up starting over a few times. We used about 5/6ft cuts per runner of the tape. The first runner may only
take you 4ft or so, we chose runner #3 since it was the shortest.
Step4: Now that you've got the 3rd runner wrapped, move on to runner #2. Start the same as you did on the other one, as tight as you can.
When you get down to the bung, double the tap over to runner #3 tightly, so you have something to hold the wrap on it as well. See image for
details of what this looks like. Keep wrapping past the converge point all the way down to where the headers meet.
Step5: With runners two and three wrapped, move onto runner #4. This was the hardest to wrap as they are equal length on the headers we
chose, so be careful with this one. Start the same, and take this one two or three wraps onto runner #1.
Step6: This is where youll use the rest of the tape as this is the last runner. Wrap as normal until you get down to the meet from the runner
#4. Wrap tightly and continue down until they converge 2-1. Double wrap the 2 runners at the bottom together and continue until they come to
one. Since we only had 50ft of wrap this is where we stopped and clamped, using the 5" clamp over both. Make sure it's nice and tight as this
is what holds all the wrap together.
Tada! You now have new headers that are wrapped up nice and tight. Kinda reminds you of Christmas morning eh?
Step7: Install the new headers. Now I had a 3" resonated cat as shown in the pictures and it didnt exactly mate with the obx flange. I think
2.5" might be ok, so I had to weld the gap at the flanges on mine. Clearance is tight near the steering column. We fed them in from under the
car, be careful not to snag your wrap. Get them bolted in and its time for a test.
Once the motor warms up the wrap will smoke like crazy. It will only do this once and it smells quite bad. Might wanna do this outside. We
let it sit idling for about 20mins then took it out for a test drive. The headers changed the power band some from the low end to more
mid/top end. The motor sounded completely different, it was deeper and much louder. It's a feelable difference, and when we parked the car
under the hood temps were dramitcally lower than before. So there you go, enjoy!
