deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Thu Feb 19, 2004 7:08 pm
Ok everyone ive been wanting to post this up for a while. I found lack of info on the new obx header when i was deciding on buying it. For anyone that is interested here are some pictures.
notice the header is definately stainless, my engine's exhaust gas temperatures are probably a bit higher than normal at the moment, so colored results may vary
Heres another, and you can see the main drawback of the header imho. The o2 sensor location puts it right up against the firewall, i had to bash mine in a bit for some clearance, brutal. This isnt so bad, and may not need to be done, but the o2 sensor cannot be installed/removed without it.
Overall i am very pleased with this header. The exhaust flanges fit up nicely, clearance of steering arm is good, egr tube locations are good (although mine are deleted, i did check this). The header does come "close" to the block/transmission and floorpan of the car, but there is ample clearance. I have not yet checked how much total heat this is going to put out, i may need a heatsheild above where it connects to the rest of exhaust system
I have not had much driving time with my current setup, but first impressions are very good. Exhaust note is very nice, i will add further comments in the future. Please ask any questions if you are interested in this header!!
btw. i apologize for large pictures
