Yep, the O2 is a pain to get to because of the steering rack if you don't get it in first.Everything else is a piece of cake on the install.I bought one way back when from Opt-Auto, but the Ebay ones should be exactly the same.FSUDrifter wrote:I have it on my 1990. It looks cool, sounds better, added some high end power. Make sure you install the oxygen sensor before you install the header. Also the egr hose has to be bent a little in to match the fitting.
ur correct the only header that is is the dc sportssleepyRPS13 wrote:i dont think its carb approved.
