Obtaining Service Records
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
armadafor5
Purchased an 05 Armada used and want to see what kind of service has been performed in the past. In particular I want to see if the brake part upgrade was completed on the vehicle as it was manufactured in Jan 05 (before they started putting on the beefier parts in the factory). Does anyone know an easy way to obtain prior factory/dealer service records- will the Dealer easily give that up????
Thanks
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
Did you purchase it from a dealer or a private party?
armadafor5
Private owner...
keg97
Car: 2008 Infiniti QX56 & 2004 Acura TSX
I would think that any Nissan dealer can run the VIN and get the entire service history
Timmbo
I would try what Keg97 said, also you may be able to contact the previous owner, and ask them where they had their service done. Usually all maintenance is tracked if it was done at a Nissan dealer.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
