pella »
https://forums.nicoclub.com/pella-u154657.html
Fri Mar 23, 2012 9:15 pm
Do you mean the plug for ECU to scan tool? It takes an OBD2 scan tool (code reader) but ive been told if i have 1 O2 sensor its OBD1, if I have 2, then OBD2. Help. I am a bit confused, my ECU takes a OBD2 code reader but i dont see another a O2 sensor. I have 1 O2 in the manifold but thats the only one, besides a AEM wide band in a test pipe, using as read only, to the UEGO gauge. Trying to troubleshoot P0170. MAF has been cleaned. O2 sensor reads .1 VDC at idle, .9 VDC at about 4K RPM. I can hear a vacuum leak wich I have read can cause this code, but I cannot locate. Also, I have always had a problem with the #3 spark plug wire coming up a bit off the valve cover, seems to not seat well on the plug, regardless of wich plug or wire I have used (swapped). I have swapped plugs and wires but no matter what, number 3 always back off. I have a new head (remanufactured less than 10 K miles) Any help would be appreciated. Thanks.
