OBD1 to OBD2
beezkneez
Car: one slow 240sx
If you swap a DOHC into a OBD1 chassis, do you need to have an OBD2 lower harness also?
As in the Engine harness and ECU are OBD2 but the lower harness is OBD1?
Thanks in advance
beezkneez
Car: one slow 240sx
and would it affect the fuel pump or ignition if I didnt swap the lower harness?
beezkneez
Car: one slow 240sx
I got an s14 with a KADE swap.
It had three wires coming off the O2.
But if it was in a OBD1 chassis before mine, and used the OBD2 engine and ecu harness, but the lower harnes was OBD1 would it affect spark and crank or fuel?
