rustest86 »
https://forums.nicoclub.com/rustest86-u32079.html
Fri Jul 03, 2009 4:41 am
i put an s13 head on an s14 block in an s14 and the only 3 differences that i found was 1 10mm bolt that goes trough the head to the block on the exhaust side in the front didnt line up, and the upper timming cover didnt seal up, the cover had one spot that bulged out under a bolt. and the valve cover had a different bolt pattern. make sure you get the s13 upper timming cover and valve cover too. other than that it works just fine.
