In reality, you need all new coils. I tried substituting them in as they failed and it was a dog chasing its tail.
You need to replace both knock sensors. This involves open heart surgery. But on your way in you will be able to clean the the EGR and IAC valves and unclog the EGR tube in the top plenum. I assure you it is clogged completely closed. Replace at least the bottom cooling hoses off the T to the heads. 2 KS and I would recommend harness. Be very careful removing the clips on the injectors as they are brittle and brake and unlike the VH45DE, you have to buy the whole EGI harness to replace them.
Check my post for where to send your injectors for cleaning. You will need all gaskets (3 on the EGR alone), and it will be an excellent time to replace plugs and valve cover gaskets, and of course new coil packs. It will run until you die then you can be buried in it, assuming you have maintained the PS, brake and differential fluids.
The Church of the Holy Plenum Job will take your calls 24 hrs. a day. Arise and go forth and smite the carbon build-up!
If you don't, your car will be like your avatar, dead.
