2s4k0y09 »
https://forums.nicoclub.com/2s4k0y09-u24213.html
Mon Aug 27, 2007 6:57 am
Hey guys, I searched and search, came across a couple threads going into a little bit of detail about the conversion harness to run an OBD 1 ecu in my 97' S14. I know mostly how I want to set up my turbo kit, but I'm trying to reassure myself that i'll have a rock solid tune of the ecu ( I love my car too much to skimp on any part of this to avoid blowing it up). I keep hearing good things about whether it be JWT, or other companies who do ECU tunes to obtain the proper AFR's and timing retard under boost condtions, expect it's all for obd1 240's.
Original plan: -Dtec FC w/ knock sensor... - BTM for timing - Wideband O2 sensor regardless of set-up
Goals: HP= 280whp- 330whp TQ= 300wtq Redline= 7200rpm Full boost by 3200-3500 rpm
This is going on a stock motor which I've babied and taken very good care of over the past 7 years I've owned her, right at 97k on the motor, good compression.
These are my supporting mods I wanna go with: -550cc top feed injectors w/ project silvia rail, SSbraided lines to hardlines -Walbro fuel pump -Z32 MAF - Colder plugs - Nology hot wires ( Already installed) - MSD blaster coil - RH manifold TM -Tial wastegate w/ atmosphere dump -Turbo XS BOV - Intercooler and all other piping - Rotomaster T3/T4 .60 a/r comp/ 1.00 a/r tubine (don't have trim specs) *I might be switching to a T3, but I'd like to run my current turbo with low boost for now, around 8psi to 10psi till I build my other block and head up. - Vacuum block - gauges and such that are required.
I'm learning from all you guys what to do and not to do, this is my first turbo project, but I have too many hours to list in research and time under the hood, there is just so much out there in the way of tunning options. I've look at other guys set-up that are compareable, but I haven't found anyone with the exact set-up as mine, which I'm not really suprised by.
New plan: (not dead set on a way yet) - Tunned ECU to what I'm looking at installing ( injectors and MAF and goals) -OBD2 to 1 conversion harnessReally don't want to go the way of AEM EMS due to the fact that emissions will be an issue in another 2 years. *or*I've heard talk of AEM having a new piggyback controller that does fuel and timing, but no set date on when they will have a harness for 240's. Don't wanna wait around for that, but still holding as an option.
So in all this jumble I just typed, my main question is for you 96' and up S14er's who run this kind of set-up and your experiences with it good or bad. I've heard you can re-pin obd1's into my existing ecu, but I'd rather not do that. Any feedback is welcome, and I feel like I left something out of my set-up I described above, but regardless I'd like to see what you guys have to say, Thanks in advance!
