romerider153 »
https://forums.nicoclub.com/romerider153-u70210.html
Tue Oct 28, 2008 12:55 pm
ok so i got and obd2 ka in a 96 the wiring harness is pretty hacked up from the previous owner and i got a obd 1 upper harness and ecu lieing around can i just swap the harness and remove the masive amount of emisions stuff from obd2 with out much other problems i know i need to run a single wire o2 sensor but i heard something about needing to swap the dizzy as well is this true and is there anything else im missng
