chepolino22 wrote:i installed new oem ngk platinum sparks and checked connections to each coil. Car does not misfire but the 1320 code is still there.
So how did you check the connections to each coil. Did you use the info from my earlier posting?
DTC P1320 means "Ignition signal primary circuit not sent during cranking/starting. The problem may be due to - harness/connector, ignition coil internal power transistor, or camshaft position sensor/circuit.
Please refer to page EC-270 (description of of P1320 fault) and EC-273 onwards (Wiring Diagram) of the FSM which Brian (maxmix) provided a link to you. These pages will give you a better understanding on how to diagnose the problem.
Replacing the harness is an expensive and time consuming process. I personally won't recommend that unless the harness was damaged or burnt. As for the main engine harness ground points, I recommended that you clean them. There are 2 ground lugs bolted to the engine close to the oil dipstick. Disconnect the ground lugs and clean both the lugs and ground points with sand paper and then reconnect.
As for cleaning the connector and receptacles of the ignition coil, use contact cleaner available from electronics parts store. Even the CRC MAF Cleaner (@ $8) from Autozone should do the job. Then apply dielectric grease (Permatex Dielectric grease @ $5 from Autozone) to the connector and receptacles to prevent corrosion.
I'm assuming that you have already tested the coils and they are brand new anyway. So we can focus on the wiring.
Ignition Coil Connector Signal:-Pin 1 (W/R wire): Battery voltage if Ignition switch is ON-Pin 2 (B wire): Ground connection (of emitter)-Pin 3: (striped wire): Signal from ECM (base bias to coil transistor), - 0.38VDC with Ignition ON or engine at Idle; 0.56VDC at 2000 RPM.
You have to check each connector to the ignition coil. With Ignition ON (engine OFF), check that:-Pin 1 has Battery voltage (@ 12.6VDC on a good battery). If not, you have a break somewhere between the Fuse Block and the connector.-Pin 2 at 0VDC. If other than zero, that means the ground connection is poor, dirty or broken.-Pin 3 is @ 0.38VDC. If there is no signal, you have a break somewhere between the Ignition Coil connector and the ECM connector.-Also make sure that Pins 1 & 3 are not shorted to ground.
