ob1 and ob2
sleepyeyes
Car: '93 240sx Fastback
bla bla bla..i have a '90 e and want to put a '98 de.....as long as i have all the engine stuff (harness, transmission, ecu) it is just a plug and drive or is there some converting of the harness....or can someone direct me to a previous post here or somewhere else....thanx
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
why the hell would you purposefully curse yourself with obd2?
GEO
Car: 95 240sx KA-T
yo, I am wondeirng same thing. considering I am going to be purchasing the greddy Kit... I am going to need OB2 for my 95 S14
yellow_jacket
Car: 95 240sx
Yes it will go in. You will also need a maf, p/s lines, gauge cluster, and maybe a few other things. There are quite a few posts on this. Even if you don't get all the stuff from a 98, you can use the S13 lower manifold, wiring, distributor, ecu etc so that you can stay OBDI. Not to mention the wiring should be much easier that way.
