EHILL wrote:As far as other issues I can't think of any after the battery swap. My car has been making a weird noise when I put the car in reverse. It maybe a motor mount. The sound is like a loud click.
It sounds like you might need to get your base idle reset. If you still have factory warranty you can bring it to them with a complaint of "High Idle, please reset variable parameters" they should cover it without issue. If they want to try to charge you and you want to do it yourself but it is not easy and requires some serious patience.
The Clicking Noise could be one of two simple things. Each of which can be isolated with a very simple test. Apply the parking brake (only a few clicks) and shift into reverse, if the noise persists it is more likely emanating from the rear CV to Hub mounting surface. As torque is applied they shift and there is no lubrication between the two metal surfaces a noise may occur. There is a service bulletin that addresses this incident in some other vehicles. It basically tells you to remove the axles, apply a high quality Molycoat grease, and re-torquing the Axle nuts and replace the Axle shaft bolts. My advise is let them know you know about this procedure so that they do not just re-torque the bolts, in a polite way
The other possibility is the noise is coming from the parking brake. I find that right around the time the rear brakes need replacement, the parking brake usually could use a slight adjustment. There are two adjustment points, one on the pedal assembly, (although, this will not effect your noise as much as the second) and separate star wheel adjustments inside the rear drum assembly. After removing the rear wheels you will see a small rubber plus. The way I adjust them (if removing the rotors to re-surface them) is to thoroughly clean them and sand the shoes just enough to give them a new finish. After the rotors finish their slow cut and I apply a non directional finish (they are both aesthetically pleasing and the proper way of doing it) with Emory cloth. After putting the rotor back on the hub and turn the star wheel (I don't really know the best way to describe this, insert a medium flat head screwdriver with the handle towards the studs and adjust in an upward direction) until you feel resistance then back off the adjuster about two movements.
Sorry to run on a little.
New2Import wrote:
Ive had very high idle at times..I bought it used so I dont know the history. My transmission kinda lunged when we first got it. On hills it would kind bunk like a manual transmission at times when you dont hint the rpms and it was hard to duplicate so I didnt have any more thought about it. Thought it was part of having a manual/auto transmission. Im new to the technology. Ill do that and procedure for sure and keep up now. You need to post more often. You have alot of knowledge. Thanks.
At no point should the idle ever be over ~1800. Your Base Idle Air Volume may need to be reset. The VK has no known issue with throttle control, and if the idle is consistently high (<700 during closed loop operation) the increased load can and will cause accelerated damage to the other driveline components. Nominal base calculated load should be ~20-25% (VK) and 13-27%(VG) with all loads off and an ambient temperature at around 70*F, at sea level.
I try to get into as many topics throughout the Infiniti forum, I do miss a few here and there and have a decent backlog currently. If you have any direct questions that you want my opinion on feel free to email me.
I see in your sig you have one of my favorite Chevys. The mid90s Impala was a great car, if kept correctly. The Police Package was the fastest one I got to drive when I was growing up and they were the last of a dying breed of powerful land yachts.
