O2 Wideband
S13FX
Car: '69 l20b Dimeski :)
Hey guys, I did a search for 02 Wideband but it looks like the topic isn't covered very much. Here is the deal. I got all my KAE-T parts and Im starting the project at the end of March.
Right now Im putting in simple stuff like new fuel pump, filter, etc etc. And working out my bugs as I go. Here in the next day Im also going to wire in my Emanage Ultimate. One problem I have come across is the O2 Sensor. What I want to do is have a wide band O2 sensor wired to the Ultimate since it gives you extra tuning options once that's in. My only deal is every where I look they only come in a full package with the o2 data logger and stuff, and I don't really need that. I also found a thread where it mentions there is wideband sensors out there with two out puts where for you stock connection and one for you emanage. But I find that kind of pointless since Im going to intercept the O2 output right before it gets to the ecu.
My question is can I just buy this
http://www.innovatemotorsports...age=1
plug it into my stock harnest and use it for now. And then when I do wire in the Ultimate it will actually have a purpose...
What are your guys thoughts on this?
Thank you
GEO
Car: 95 240sx KA-T
plx m-300 , just ordered mine
steve s14
i think you need the lc-1 at least. the thing you're looking at is just the sensor. i don't think that the stock ecu will recognize the signal from a wideband anyway.also if your car is turbo, you will have to mount the sensor further down stream from the stock location if you want the sensor to last long.
