O2 sensors
mick
Car: 1990 240SX
I bought a generic O2 for my SOHC S13 engine. My check engine light is on for a few minutes whenever I start my car. Does generic not work as good as the O2 made for Nissan?
onosqv
Car: '92 240sx Vert
should be fine. pull ecu codes & see what the ecu is complaining about.
mick
Car: 1990 240SX
Does someone make a good code scanner for the 1990 S13 SOHC?
KillTheApex
Car: 1991 Nissan 240sx
I'm pretty sure there is a way to read it directly off of the ECU itself, unless SOHCs are different.
Look here.
KillTheApex
Just an update. I checked my ECU codes and guess what? I need an O2 sensor as well. I figured I did because of my 15 mpg but this confirms it.
