Magnum PI »
https://forums.nicoclub.com/magnum-pi-u32447.html
Wed Nov 28, 2007 9:11 pm
Just did the passenger side one this past weekend. Fortunately my buddy had an O2 removal tool, as it is hard to get to and get the proper leverage to loosen it. Thought it might be part of the cause of my intermittent bucking and stalling. But nope. it still runs the same. Havent noticed any improvement yet, but the search for the cause of the more problematic performance issues probably takes away from any positive effect the change might have caused.
In short, if you like to wrench, this is a contortionist's delight. Had to cut the wire to get the tool over the sensor, pull the wire out of a little clip on the back of the engine block and then reinstall. Took about 1 hour. Would have been more fun if it solved a problem.
