cmkelly wrote:It cost me $95 to have my ECM reprogramed so as not to burn out the newly installed sensor. I understand this to be a common problem for this year.
You were ripped off re: reprogramming the computer. Like you said, that hours' worth of diagnostics was pure B.S. Nissan knows about the reprogram, and has a bulletin on it. It should have been free.As for the O2 sensor failure, it's a common problem. If one goes, the other is sure to follow. Happened to me too. However, from what I can tell, it seems in a majority of cases, it's only the 2 rear sensors that fail. Replace them both, and you should be OK.
