tech, can you elaborate on this? What does slower "switching states" mean to the average roadwarrior?Q45tech wrote:O2 sensors are much like spark plugs, fuel injectors, filters and knock sensors................devices which wear out and need replacing.
Most things are designed to function for ~~100,000 miles before degrading to the point where the engine runs better with new units than with old ones. Somethings vary with conditions and last longer depending.
O2 sensors degrade by taking longer and longer and longer to switch states.
I'm not tech but I'll throw my 2 cents in. The sensors read the amount of oxygen in the exhaust and the ecu adjusts the fuel/air mixture accordingly (and probably 10,000 other things), as they age they cannot read the oxygen content fast enough to compensate in for changes.paranoidjack wrote:tech, can you elaborate on this? What does slower "switching states" mean to the average roadwarrior?
maxnix wrote:Less precision in the injector timing.
Remember OBD II cars with V engines and true dual exhaust have four, two before the catalytic converters that do the heavy lifting, and two after that do the fine trim.
Why it is always a good idea to replace in pairs as the swtiching rates will be different if one is worn, so everything is a little less precise bank to bank.
Get OEM from Joe or NTK from http://www.sparkplugs.com, but call to verify as the website is often wrong.N.O.C. wrote:Thanks for the info, any idea what the charge is on a Q to have them replaced?
Seems intuitive that timing (exhaust gas flow) would vary somewhat with rpm, or is that just plain wrong?Q45tech wrote:Easy to chart out each O2 cycle and match it with a cylinder to find culprit with digital oscilloscope synced to #1/#2 firing and time delayed until the exhaust occurs and has time to get to O2 [speed distance]
