xmaciek82x »
https://forums.nicoclub.com/xmaciek82x-u268344.html
Sat May 19, 2018 4:30 pm
OK, for some unknown reason, I cannot edit my original post, so i guess I'll make a reply to myself with some further findings and corrections to my original post. Correction, above should read that original CEL was with bank 1 sensor 1 and bank 2 sensor 1. I also wanted to correct that after driving around and data logging, I noticed all 4 o2 sensors behaving correctly. Voltage moves between .01v and 1v.
What was odd is that bank 1 Short Term Fuel Bank and Fuel Trim bank 1 sensor 1 (not sure the difference between the two) both read 0%, while bank 2 moves accordingly with +/- % readings. Would this indicate fuel problems? If so, what could be the next thing to troubleshoot/replace?
