o2 sensor wiring
nemo6686
Car: s13
I am extending the o2 sensor wires. The white wire is shield it has wire inside the wire. How do you guys solder this one. Do you just solder the wires all together as one wire.
StorminNorman
Car: s14
They are seperate
nemo6686
Car: s13
so you extend the inside wire first then extend the outside wire right
StorminNorman
Car: s14
That would be correct.Why are you extending the wire?
float_6969
I've neverr had success soldering the shielded part of the wire. If you wrap the connection in aluminum foil, it seems to work just as well.
