SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Fri Oct 08, 2004 2:55 pm
I dont think the brown wire on the KA harness is what powers the O2 sensor on the SR harness. This is why heavy throttle specifically tells you to find a twelve volt source and not splice the brown wires together.
The disconnection of the O2 sensor may not give off any audible clues whether its working or not. If I disconnect mine, you dont hear or feel anything, but if hooked up to an emission testing device you will see the O2 emissions at idle go down, and emissions at the higher RPM's skyrocket.
