O2 Sensor wiring question.
emiliog2276
Car: 1990 300zx 2+2 NA
2002 Nissan Sentra GXE
Im wiring new connectors to the wiring harness. I was just wondering the signal wire (white) coming from the wiring harness has some wire shielding on covering it. When connecting this to the new connectors is this wire also part of the new connection or do i strip that and only connect the wire below that.
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
If it has extra shielding on the wire its probably just some kind of heat shield/protector. As long as you solder and shrink wrap the new connection it should be fine.
