got2b240 »
https://forums.nicoclub.com/got2b240-u18026.html
Wed May 11, 2005 3:11 pm
On My 02 Sensor wires (3 of them), (engine running & operating temp) I have the two outter wires reading 12v and an inside middle wire reading .200v - .350v, this voltage doesnt move around at all even if i rev the motor and let it idle.
Questions:
1. Am I supposed to have two legs with 12v on each out of the three?
2. Judging by the middle (im guessing signal) wires voltage, and how it doesnt cycle voltage (change), my 02 is shot? Or is it because I have 2 legs with 12 volts and no ground?
Since I aqm running a Type-X harness & motor and a E6 ECU maybe there is a reason for the o2 harness wires arent where they are supposed to be at. Is there supposed to be a ground? Or is this normal, but I have a bad 02 sensor? Or is this a good 02?
