sdkhalsa »
https://forums.nicoclub.com/sdkhalsa-u28278.html
Mon Apr 02, 2007 5:03 am
For my 94' Q I used a standard flare nut crows foot at the end of a medium(5"?) and short extension(3") with a swivel between the two extensions. I inserted this combination at the center slightly to the driver's side along the firewall. In order to make that insertion it was necessary to release the cableing that is held down at that point. I think that I also pulled-off the brake vacuum line off of the manifold. The trick to this operation was to climb on top of the engine with a flashlight, and turning your head at a particular angle, so you will just be able to see the crow's foot engage the sensor. When things are arranged well, the crows foot will come down in-line with the sensor. One word of caution, avoid wobbling the extension as this can break the top of the new sensor. In my case, once the sensor turned about a quarter of a turn it would go the rest of the way with almost no effort. The crow's foot that I used was a Proto Brand 7/8" with about ten points. These numerous points allowed me to engage the sensor very exactly. If you have further difficulty, please let me know and I will send a picture.
By the way, when I did the passenger side, I used a very long extention(maybe 18") and threaded it down from directly above, positioning the crow's foot from underneath the car with my hand. It worked great.
