o2 sensor
240sick
Car: white 96 s14.5
what would be the result of me taking out my o2 sensor then adding seafoam to my car to clean it, the reasion is i just got the o2 sencor and i dont wanna replace it yet so can the car be ran with the sencor out or disconnected while i clean it and also am i right in saying that there are two o2 sencors on a 96 240 thx:confused:
Ladybug
i don't see a problem running the car w/o the sensor just for cleaning purposes.
[s3]
You can run the car w/o O2, it'll run like crap but why remove in the first place?
I think seafoam causes no harm to O2 sensors.
240marcuSX
Car: E34 525i
E46 M3
just run seafoam through, then switch out the plugs and 02 sensor.
240sick
Car: white 96 s14.5
ok so are there 2 sensors on a 96
s13EastTN
Car: 91 s13 hatch, 95 Honda Civic
Well O2 sensors aren't exactly cheap, I beleive this is a good idea, but I would plug the hole.
IlIkEmYz
Car: 06 Z
an experenced mechanic that used sea foam for 20 years told me that the O2 sensor does not need to be removed, he also said that the sea foam cleans it.
Jstyal
Well the reason it is reccomended that you replace your O2 sensor after using Seafoam is to insure the sensor is carbon-free after the cleansing.
Instead of replacing the O2 sensor, I would just take it out, plug the hole, run the Sea Foam procedure, then insert the O2 back in.
240sick
Car: white 96 s14.5
lets say i leave the sensor in durring the cleaning process what will happen to the sensor/s
240sick
Car: white 96 s14.5
b/c my sensors dont even have 2000 miles on them yet
240marcuSX
Car: E34 525i
E46 M3
i went ahead and replaced mine anyway. it was a part that i had yet to replace. and lately ive been tuning my **** up.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
THe 2nd O2 sensor ont he S14 is NOT used for tuning at all...it's there to tell the ECU if you have a functioning cat.
So if you feel the need to replace the sesnor, only do the primary one...
Just FYI...
- Brian
sohc90adel
Car: 1990 Nissan 240sx HB 5 speed Grey
Can sombody buy me seafoam and ship it to me priority mail? I have paypal.
