robdancarter:
One choice is to get the "universal" one, and cut your old cable and splice it to the new
sensor (splice comes with the universal sensor), so that you re-use the original connector
to the harness. Problem is, that it can be difficult to get a sufficient length of the old cable
out, because it is impossible to reach the anchor points. This is especially true for the
downstream/rear/sensor2 on the passenger side, but also difficult on the driver side.
I found it easier to just pay the extra dollars to get the one with the correct connector.
Be aware that the connector changed during the 2001 QX4 year, either a green connector
or a gray connector -- these are not interchangeable, will not fit. You need to look
at the connector yours has, and then go to the Bosch site at
http://www.boschautoparts.com/VehiclePa ... inder.aspx
enter your year/model, select oxygen sensors, etc. Eventually, you will find
"early" and "late" production choices. For the Universal one, it is the same part number,
since you would reuse the connector/cable. For the OE fit one, there are two
different parts. For instance, the downstream left side (I think that is bank2 sensor2,
but you need to verify)
http://www.boschautoparts.com/VehiclePa ... _num=13651
for late production, and
http://www.boschautoparts.com/VehiclePa ... _num=15445
for early production
RockAuto is one of the few parts sites I found with actual photos to show which connector.
They were also about the cheapest, and I ordered from them.
Gary
Edit: The rear/downstream sensors themselves are easy to get to from under the vehicle.
You can fish the connector/cable through with a fish tape or coat hanger or some such.
The fronts, which I'm planning to replace, seem very difficult to get a wrench on.
Anyone with advice (especially driver side front O2 sensor) of how to get at it?
