4wheelsoffury »
https://forums.nicoclub.com/4wheelsoffury-u150056.html
Sat Dec 04, 2010 1:20 pm
I vaguely remember reading some info about the o2 sensor wires in the left underside of the dash, correct me please, but i think one connector is for a 50k mile warning lamp and a second connector for 100k warning. I had a lit sensor lamp for a while and I disconnected both connections and the lamp went off. All that is fine but I just cracked 100k, so I got a new sensor and installed it no problem, put connections under dash back to factory....the sensor lamp is still lit !!!! It has always ran fine, and I could tell no diff with new sensor, but I do not know if the sensor is operational, maybe it is supposed to run better and I just think its running fine ? Either way, I need to make sure the new sensor is alive, and the sensor lamp is all I have. Do I need to change the dash connections, or something else to make sure the new sensor is doing its thing ?
