Q45Viper »
https://forums.nicoclub.com/q45viper-u6953.html
Mon Jul 07, 2003 3:36 pm
I posted a few weeks ago about a slight miss or stumble I had on light acceleration passing through 40-45 mph. One of the responses I got was a possible bad O2 sensor, I wanted to live with it a little bit as I played with low speed in third instead of drive to eliminate the transmission. I think I did. Plus I just flunked emissions test in Maryland and the brain surgeons administering the test told me it's probably the O2 sensor. That's fine, more info for me for $14 and I got till Nov. 4th to fix or spend $450 to document I tried to fix it. The last part will be easy, right? anyway, it flunked Oxides of nitrogen, NOx. supposed to be 2.3000GPM and it did 3.5902GPM..... HC fine at 0.5188GPM and CO fine at 3.1656GPM, CO2 as read at 547.3837 is a non pass or fail item.QUESTION....Does this tell me I DO have an O2 sensor problem or sonething else....and if I do have an O2 sensor problem what else should I have done at the same time, is this a plenum pull to get to the sensor? that means do the cleaning and replace ALL hoses right? How about the injectors underneath? Car is due in on Wed. to the guys who did my chains, I have read enough to know I don't wanna go underneath this plenum twice. Advice?92 Q Federal with traction 130k Guides, transmission, air, sunroof and lots else done.Thanks, Lee
