O2 Sensor question ?
bj-99
Car: 2000 i-30
What's the problem with continuing to drive the car with an O2 sensor out? Does it damage anything else? Car passes emission test in Az just fine
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
about the only thing you might see a difference in is gas mileage. other than that, it should not affect too much. IMHO, i would change it out and get your CEL reset so you're on top of everything.
MaximA32
How do you know it's not working? Is your CEL on?
maximalxl
Car: Nissan 2002 Maxima (Pearl)
i would suggest you replace it.....because u will hve to replace it sooner or later.....
lightsout
Car: 00 Nismo Maxima SE
I just replaced an 02 sensor...what's an CEL???
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
If its after teh cat dont really worry about it if you dont want too. If its before the cat. I'd change it if its throwing codes.
MaximA32
CEL=Check Engine Light
lightsout
o...i shoulda guessed that...duh.
gumbyandpokie999
o2 sensor just changed in a 2002 maxima bank 1 sensor 1 ,now bank 2 sensor 2 shows up and it says some kind of performance issue problem,car gets 38.6 MPG check engine comes on randomly.Runs fine after a reset,died in LIMP mode twice,lucky I carry my trusty orange scanner and just reset it. Car has 58K,running synthetic,premium gas only. Any ideas what the heck I do next?
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
The computer will tell the engine to run in a "rich"fuel condition if the O2 sensor is out
Check the sensor with a multimeter
gumbyandpokie999
Should I just replace the whole dam exhaust system and put in stainless steel and all new O2 sensors?Car had P0139 and P1147 now has P1165 and is telling me bank 2 sensor 2 is low output,AFTER changing Bank 1 sensor 2,having the fuel injectors cleaned at Nissan.Very frustrating .Car sits in the driveway M-THURS ,do you think its just rotting away? Should I disconnect battery when not in use?Any ideas?I like my car ,dont reallly wanna trade it in.(2002 MAXIMA)
Modified by gumbyandpokie999 at 10:00 PM 10/16/2007
lightsout
2000 i30......uuummm....here ya go
P0139= ('00-'01) rear heated 02 sensor bank 1
P1147= i cant find this code, is it right?
P1165= i cant find this one either...check again maybe
don't spend $ you don't have 2, unless you want to upgrade now!!
gumbyandpokie999
Thanks for the reply,but its for 2002 maxima OBD-2 computer.anyone have any ideas>?
Modified by gumbyandpokie999 at 3:09 PM 10/18/2007
