NutriaforBreakfast »
https://forums.nicoclub.com/nutriaforbreakfast-u77129.html
Wed Apr 01, 2015 9:45 am
The 40 mile drive idea is to get the CAT very hot to process the NOX
(Nitrogen Oxide) gas. The test would show low NOX and then you get
your inspection sticket.
Your O2 sensors might be so old that they do not provide quick enough
readings to your computer.
or
On my 95, there are two O2 sensors. If the readings BETWEEN the O2
sensors are not within tolerances, I will get a check engine light.
I noticed it was just as expensive to check the O2 sensors as to buy
new ones so i just bought new ones. If you have not changed them
before 103,000 miles, i would guess you need new ones. I recommend
Bosch or OEM from Nissan.
