lakeq45 »
https://forums.nicoclub.com/lakeq45-u33559.html
Tue Mar 20, 2007 11:18 am
Search for a thread from me on this same issue. I went through two O2 sensors (the second one was under the parts warranty fortunately) before the dealer gave me a loaner for a while and really dug into things. They checked all the harnesses, re-tightened grounds, etc etc. They ended up replacing the ECM (covered by an 8/80 from Infiniti) and everything has been kosher ever since. I kept lossng the right bank number 2 if memory serves, but it should be in the old post. Might take advantage of that 8/80 if it still applies to you. I was luck, ended up with 3 O2 sensors (they killed another one while they had the car) and an ECM for the cost of one O2 sensor.
BTW. If you replace the ECM be sure to re-bless ALL of your keys. My Q got a ride back to the dealer on a flatbed on their dime because they forgot to remind me to bring in my wifes key. It was my first time with a brain transplant. Only takes once.
