O2 sensor hookup
Nissan 350z / Nissan 370z general community discussion forum
FlyBoy
Car: Nissan 350Z Anniversary Edition
First post !!
Hope you can help me out here. Did not get a response at another forum but saw that there are some people here that know a lot about electrical (Magnes/NISTECH?).
I was trying to hook up my narrowband A/F gauge to the secundary O2 sensor from my 2005 350Z. It can not be done to the primaries, because that is a wideband.I was expecting a .4 - .6 Volt readout from the black wire, but it is a steady zero. Is this because the sensor first has to reach a certain temperature or is the secundary sensor only working if the primary fails.
Anyone??
Thanks
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
the secondary o2 sensors are only there to make sure the cat is working. You will NOT get an accurate AF ratio that far downstream!!!!!
Return to “350z / 370z Discussion”
