O2 Sensor Bank?
trailshredder
Car: 1997 Q45, 175k miles
I have a Bank 2 Sensor 2 code. Is ths the Drivers side, after cat sensor?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
That's correct. Bank 2 is always the RH side, and the sensor 2 is the rear sensor. Perhaps consider changing both of them since the other one is probably on it's way out too.
trailshredder
Thanks! So Nissan calls the driver side RH?
Strangely, I cleared the code and it hasn't come back yet. Could it be something else?
qship96
Car: 1996 Infiniti Q45
In Japan
trailshredder
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:That's correct. Bank 2 is always the RH side, and the sensor 2 is the rear sensor. Perhaps consider changing both of them since the other one is probably on it's way out too.
Look at the FSM.
Bank 1 is the left bank looking forward from inside the car.
Reset code should reappear soon if sensor is bad. Same with order, from front to rear. Bank one is odd (1-3-5-7) and bank two is even (2-4-6-8).
