Raz007 »
https://forums.nicoclub.com/raz007-u160235.html
Fri Dec 10, 2010 6:28 pm
If you delete the first one, your car will run like a** if it runs at all. The second doesn't really do anything except throw a CE light. When I installed my OBX header, I came across theoe observations. Since my 2nd sensor didn't fit into the supplied hole, I took my car down to a local guy to have it welded in. Well, he misunderstood what I wanted him to do, and installed the small secondary one into the 1st sensor position. Flame city, and car ran like a** except at WOT. So I turned around, got him to do it like I wanted, and all is good. I have the OBX header, cat delete pipe, and the HKS hi power, and no check engine light. And I also passed inspection. Install both, and you'll be fine.
