PMan_S13 wrote:It really isn't all that bad at WOT, though. With all the heat it keeps it reading nicely and won't go into feedback mode due to high throttle.
Doesn't seem all that inaccurate to me at all.
I use to think the same thing. Until I found out I was running 13.5 AFRs while the gauge still showed me green.
Quote »BTW, at idle I get really varried readings. Know that the sensor only works correctly when it's very hot. So at idle sometimes it won't read much at all but the voltage going through the sensor itself due to lower temps. [/quote]
Yes it does vary a lot. Sometimes my ECU will have my car run rich at idle... sometime lean. Sometimes it goes into closed loop, sometimes it does not.
