DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Tue Apr 29, 2003 7:15 pm
Not only "as good as" factory...Same as factory. NGK made the originals. As far as I can tell, the wire type, the sensor, and the connector are identical in both units. Resistance is the same. The difference is that the Infiniti factory sensors have little plastic clips that plug into the car's mounting brackets, and they're located correctly. If I recall, one has 2 clips, and one has 1 clip, and one has a little longer wire than the other. Those are the only differences that I'm aware of.
