blackmax23 »
https://forums.nicoclub.com/blackmax23-u66692.html
Fri Feb 08, 2008 5:16 am
If it's a bad pre-cat, then you have to replace the y-pipe, depending on which bank it is. If it's bank 2, then you will have to replace the whole y-pipe, which can be pretty expensive if you buy it from the dealer. Also, if you just cleared the code and didn't fix/replace the o2 sensor, it'll just keep coming back on until it's fixed.
