float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue May 11, 2010 6:29 am
Shielded wire on your harness >>> Black wire on new sensor
Brown wire on your harness >>> White wire on new sensor (doesn't matter which)
Blue wire on your harness >>> White wire on new sensor (doesn't matter which)
Oh, and make sure that the brown wire on your harness has 12V+ with the ignition on, and that the blue wire has continuity to pin 115 @ the ECU. If not, the engine may run poorly during cold start and warm-up.
