O-rings
Kouks
Car: 1996 Nissan 240sx S14 Sr20det
So I was installing my injectors and i broke injector #1 o-ring that goes to the fuel rail. I need a new one! where do I get one?
boost_boy
Kouks wrote:So I was installing my injectors and i broke injector #1 o-ring that goes to the fuel rail. I need a new one! where do I get one?
Go to discount auto and order the o-rings for a mitsubishi eclipse or 1989-90 nissan 240sx.
Dee
Kouks
Yeah thats what I thought, just didnt know if they would have them in stock or not. I'll call around.
I knew I broke it too, and i put a tad of glue on there, and hoped that it stayed together. LOL, im a retard.
Thanks Dee.
turbo-sil40
Car: 00' Land Rover Discovery, 1990 nissan silvia conversion coupe with CA turbo swap
just go to nissan dealership and tell the you need injector o-ring and bring the old one and have them match it up for you
Kouks
Alright, I picked up the injector o-rings for a 90 240sx. The damn o-rings are a tad too big, and I know they are going to leak.
I thought the eclipse had a different size o-ring too, thats why when you put in their injectors you install ca o-rings? The pulsar nx se should be the same size right? IT is still a ca...?
Maybe within the next century my car will run properly. I'm not giving up!
Kouks
So boost boy, what do I do to get these to fit, they are a tad too big for those injectors.
boost_boy
The 240sx SOHC motor uses nearly the exact same fuel rail as the CA. I don't know what in the hell they gave you, but you do know the rings do expand some. If you say they fit loosely, then they probably do, so I would take them back and make them help you source the right O-ring. Remember, just because you ask for a certain part and they claim it's for that particular car, doesn't always mean they are correct. If you went to advanced discount, their info is all screwed-up because they tried me as well with the same issue. I am now using the 240sx seals on my car as we speak, but out of curiosity, have them get you the ones for the pulsar. I do know the eclipse/galant seals work and that's why I mentioned them to you.
Dee
Kouks
I tried the pulsar and the 200sx. TOTALLY different. I have gotten the 240sx ones twice and both times they gave me the same ones. 1g dsm should be the same though, I'll try that one, but i know the 240sx ones arent small enough.
boost_boy
Kouks wrote:I tried the pulsar and the 200sx. TOTALLY different. I have gotten the 240sx ones twice and both times they gave me the same ones. 1g dsm should be the same though, I'll try that one, but i know the 240sx ones arent small enough.
If you continiue to have problems, let me know and I'll get you some because I truely do think you're dealing with some knuckle-heads.
Dee
Kouks
Thanks Dee, I'll send you an email tonight if I got the wrong ones again, but the part number that I have for the KA O-rings is 800-9209. GP Sorensen makes them. Lemme know if thats the right part number, yeah advanced auto, discount whatever.
BACARDI_DWB
what is the one for the o-ring into the manifold for the injectors? same?
Kouks
Went to NAPA and got in two sets of injector o-rings, they are still not at tight on the injector as the ones i had on the rb injectors. Anyways, im gonna install these, see what happens. If it seals it, then it seals it, if not then im in the same leaky boat i was in before.
Alright, well after putting the injector seals on there, they injector wont go on there due to the injector o ring being too big!!
I NEED SOME THREE WEEKS AGO!
Just so you know which ones I got, they were 1992 Eclipse turbo o-rings. Too big. cA o-rings are smaller.
Modified by Kouks at 12:13 PM 9/30/2006
float_6969
Try taking the correct size,broken o-ring to a pool/spa store that does repair. My store, carries A BUNCH of different sized o-rings, and the ones we don't have in stock, we can often order.
Coincidentally, the big o-ring that goes around the seal of the fuel pump in the tank is the EXACT same size as the o-ring used on a common sand filter.
boost_boy
You do know these O-rings swell and conform via extreme heat and pressure.
Dee
Kouks
AHH! Boost boy please send me an email, i need the correct ones.
tcbrandt at bellsouth dot net
Kouks
I'm gonna try rx-7 injectors tonight hopefully they will work.
boost_boy
Kouks wrote:AHH! Boost boy please send me an email, i need the correct ones.
You got mail, but let me know how this RX-7 stuff works for you.
Dee
Kouks
You got mail. rx-7 injectors same part number as sohc ka at advance auto. 800-9209. They dont fit properly, too big!
Send me your info Dee when you return my email, I never hold on to it. (This is like the fourth thing Ive got from you now, lol.)
Kouks
^^^^^also, went to Nissan Dealership, not only could they not match it up, but guy asked me what DET in ca18det stood for. UGH, I hate non enthusiasts working at car places! Had a ponytail too, didnt even know what a 180sx/silvia was.
knightrider
Car: black 90 240 coupe
have you tried lubing the orings? that ussually does the trick and keeps them from getting cut when installing them.
Kouks
a tad of wd-40. Anyways, im a tard. I ripped it. I need 1 o-ring, but extras are always good to have.
