jsando2 »
https://forums.nicoclub.com/jsando2-u37259.html
Sun Oct 17, 2021 7:30 pm
Update:
So I did a cylinder compression check and it came out ALL Good! Still working on my fuel system. I have my fuel rail out Im just waiting for my Rings/Spacers that goes inside the manifold where the injectors go thru at the tip. Anyway I have all set up for once I mount the fuel rail which is a pain in the neck I will do a fuel compression test.
I also found a hose from the lower EGR disconnected and got it connected. Hopefully I will be able to drive my 240 again.
