O ring or Permatex?
drewusmaximus
Car: 1989 Nissan 240sx
Hi all, I'm trying to reinstall my oil pan but, I lost the pick up tube O ring. Can I use permatex or should I buy the O ring?
I'm trying to put everything back together today and the local auto parts store don;t carry the O ring in stock. So, is it safe to use Permatex instead of the O ring?
Thanks in advance!
PapaSmurf2k3
Site Admin
I'd go with the O-ring. Dropping the pan because permatex failed would suck... it would also suck if/when the permatex comes out and clogs the pickup.
essfourteen
Car: 1995 240sx
Definitely order the correct gasket. I remember it being a gasket, not an o-ring.
centralcoaster33
Car: 1997 Nissan 240SX #5
If it is an o-ring and not a gasket, you can purchase those at your local hardware store in the plumbing section. Don't forget, it has two diameters, the one of the circle and the thickness of the ring itself and you'd want to match both. I've used those for my power steering or oil or something. I forget.
PapaSmurf2k3
Site Admin
Might want to make sure its oil resistant and everything. There's different materials out there and not all will work in the application.
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Look for Buna N o rings.
