RobertsnewQ »
https://forums.nicoclub.com/robertsnewq-u29366.html
Tue Feb 28, 2006 11:38 am
Simple answer: Yes.
Complicated answer: 90-93 have thermostatic switch in the radiator that activates the fan at 210 degrees as well as the independent circuit from the AC cluitch control.
94-96 USA models have two-stage fan controlled by ECU considering temp. 94-96 Canada models have single-stage fan controlled by ECU. 94-96 do not have thermo switch, but do have independent AC clutch circuit control.
